Heavy Home and Business Use Under 400 bucks build
sdep777
63
Worked up this new PC build for myself, I would like some feedback on parts etc.
Will be used for:
Word,Excel,Converting Video and burning DVD'S and CD's , Internet, lots and lots of Internet research,watching news videos, and training videos, streaming TV Shows and watching movies, also listening to Music as well.
Do not Need :
OS
Keyboard
Mouse
Speakers
Monitor
Case
Budget for Build is Under 400.00 for the needed Components.
Will be using Windows XP x64 as OS
Purchasing through New Egg Only
New Build Consists of :
Motherboard
ASRock E350M1 AMD E-350 APU (1.6GHz, Dual-Core) Mini ITX Motherboard/CPU Combo
Cpu
On Board 1.6 AMD Dual Core, Overclocked to 2.0 GHz
Video Card
On Board AMD Radeon HD 6310 graphics
Memory
Kingston 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory
Total of 8Gig
Hard Drive
Corsair Force Series 3 CSSD-F60GB3-BK 2.5" Internal Solid State Drive (SSD)
60GB , SATA III , SandForce SF-2200 , Up to 80,000 IOPS
Power Supply:
Antec EarthWatts Green EA-380D Green 380W Continuous power Power Supply
DVD Burner
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04
Grand Total: $349.94
that should be an adequate office PC for basic word processing and web browsing, including video. I wouldn't push it to do much more. I'd also suggest Windows 7 Home 64 bit over XP 64. Its much better on memory and CPU overhead than XP.
DaveUK
383
I shuddered at the idea of converting video on that CPU. Are you sure you can't stretch the budget just a little to accommodate something with a bit more oomph? I really think the machine is underpowered for what you're looking to use it for.
Even modern web and multimedia content - flash, HD video, etc - may struggle with that processor, even overclocked.
