Question Height Clearance for an AIO Cooler
IDProG
810
14
5,165
80
I'm designing a case from a scratch.
My case design will be a console form factor case.
How tall CPU Cooler height clearance needs to be to just barely fit any common 120mm or 140mm AIO with the fan?
If I replace the fans with low-profile fans (NOTE: Low profile fans are usually airflow-focused, not static pressure), will the AIO still perform the same?
Keep in mind that the water block also has height.
Thank you.
