Hello, Can u help me with this system build guys, please :)
Toaki
First of all, sorry if my english is bad, isn´t my native language so...
well, i was keeping some money, and finally i think i´m ready to build my own pc, this is the first time that i build one, so could u tell me what do u think?
(I want it for gaming , MMORPG´s also for my work 3Dmodeling/animation in Autodesk Maya and zBrush)
Procesor:
-Intel Core i7-4770K (3.5Ghz-3.09Ghz turbo),
-cores.-4; Cache 8MB
-Arch.- 4th gen "Haswell"
-Graphics Intel HD Graphics 4600 (up to 3 screens)
Motherboard:
-Gigabyte GA-Z97MXMX or maybe Gigabyte GA-G1.SNIPER Z97
RAM:
-8GB DDR3 Kingstone Fury ( i can upgrade up to 32 later)
HDD:
-1TB Seagate Barracuda 7200RPM / 64MB Cache
Graphic Card:
-Nvidia GTX760 Overclock
/2-GB, 6000MHZ, 500 Wats (6-pn X2), Cuda cores 1155/
Power source/brick (i don´t know the word in english xD)
-Cooler Master Power Extreme II EX2,625 Wats
/don´t worry for the case, i get 1 from a friend, also de O.S. could be 7 or 8,
Total price: like 1300dlls (i know that maybe i could find the same components in america by a lower price but the shipping fees to mexico and those things will be the same
I´m not to good with computers and those things so i would appreciate your help.
Thenk you and forgive me for my bad/poor english
Oh and if you don't plan on overclocking the 8350, you can get an Xeon E3 1230v3 which is the same as an i7-4770 but it does not have integrated graphics (But you are using a GPU anyways so it will have no effect)
If you're only going to be playing MMORPG's then this is really good.
If you're going to be playing other games, ditch the 4770K for an FX 8350 and get an R9 280X
If you are not going to be overclocking, get the Xeon E3 1230v3
thank you very much, but, i dont feel confortable with an AMD, i don´t know why,is just like, im used to the intel family, but looks like u know much more than me, so i´ll check the difference in prices, if is less than 100dlls maybe i´ll take it, thank you GRUxTSAR
