Hello Folks IS THIS A GOOD BUILD FOR 3d rendering extreme and Multi
JohnMalaco
MotherBoard: Asus P9X78 DELUXE
MemoryRam: Gskill F3-17000CL9Q2-*32GB*ZH 2133MHz
CPU Processor: Intel I7 3960X 3.3GHz 15MB
HDD: SEAGATE 2TB 64MB
GPU: PNY Quadro 4000 2GB OR AMD 7970 3GB
Solid State SSD: KingsTon Hyperx 120GB
CPU COOLER: Corsair H80
CASE: Silverstone RAVEN 2
PSU: Silverstone 750Watt Strider Gold Evolution
O.S: Windows 8
Optical Drive: normal samsung 22x
please give me some good advice
of what is the high performance for 3D Rendering & Multi Tasking ETC:
they also say that is Intel XEON is the best prosessor for 3D Rendering PhotoShop etc...
i have no problem spending More Money On a PC
thank you tomshardware Memebers:
please reply below
excella1221
2,415
144
Get the i7-3930K instead. I don't care if spending more money on a PC isn't a problem for you. The difference between the 3930K and 3960X is so little it isn't worth the extra $500.
Get a high end air cooler instead. All those expensive components will be destroyed if that H80's water leaks.
Get the OCZ Vertex 4 128gb or 256gb instead. Kingston HyperX is... okay, but I don't think it's any close to be as good as the Vertex 4.
Workstation cards would be better for your usage. Only get the 7970 if some gaming will be done in your computer.
IMO, you're overpaying for the motherboard, get this instead.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131800
I personally think 32gb of RAM is ridiculous, if you're not doing any server-related stuff, or you won't be having insane amounts of VMWares, 16gb should be more than enough.
Xeon CPUs are for servers. Pretty sure the i7 performs just the same or even better in terms of rendering.
Similar threads
