Question Hello, have a problem with my resolution settings. PLEASE HELP!
Mar 1, 2021
Hello Community,
Always when I try to change my PC's resolution settings from 800 x 600 to 1366 x 768 and apply. I get a blank/black screen. This problem occured after a driver installation with a online driver setup tool. Please help I wan't to change my resolution settings from 800x600 to 1366x768.
Thank you
Lutfij
Make and model of your graphics card and the monitor? How are you connected to the monitor? Mind sharing the name of the online driver setup tool? You're advised to steer clear of third party apps that tell you if you need drivers updated. You should always source the latest drivers from your GPU manufacturer's support site.
Also, you should use DDU to remove all traces of your GPU drivers and then reinstall with the latest, in an elevated command, i.e, Right click installer>Run as Administrator.
Mar 1, 2021
The name of the software with that I intsalled the driver is driver pack solution. My Graphic Card Driver is Nvdia GeForce 920MX. But on dxdiag on the display tab my pc shows The standart vga graphics adapter.
