Hello. I am a beginner PC builder and I need some help on the compatibility of my build.
Zachary_Baird01
Commendable
May 2, 2016
So I am building a full-tower build, and I am not sure if all of the parts are compatible. I am half-sure that everything will fit, and I was wondering if one of you guys could help me out. The full specs are here:
Corsair Obsidian 750D ATX Full Tower Computer Case
2x AOC G2460PQU 24" Monitors
2x EVGA GeForce GTX 980 ti Hybrids
CORSAIR RMx 1000W Power Supply
CORSAIR Dominator Platinum 32GB (4 x 8 GB) 288-Pin DDR4 2666 Desktop Memory Module
ASUS Z170-A LGA 1151
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151 91W
Microsoft Windows 7 Professional SPI 64-bit-OEM
Cooler Master V8 GTS
Samsung 850 EVO 2.5" 500GB SATA III
Samsung 850 EVO s.5" 1TB Sata III
Do I need to check anything else? Am I doing anything wrong? Thanks.
(I did check the dimensions, but I'm still not sure.)
gumbob3
Respectable
Mar 5, 2016
410
20
Looks like an awesome build, but just one question. What will you be putting on the 1TB SSD? Also, enter all of these parts on pcpartpicker.com It helps with price, organization, and compatibility.
Zachary_Baird01
Commendable
May 2, 2016
Well, the 500GB is going to be my OS and my program storage (Program being things such as Blender), but my 1TB will be things such as game files, pictures, media, stuff like that. I did enter these parts in pcpartpicker after I chose the parts, but I do know that there are special circumstances with size compatibility.
gumbob3
Respectable
Mar 5, 2016
410
20
Unless you are going to be putting and taking pictures off of the drive every day, you would be much better off spending your money on a Hard Drive. Using an SSD for pictures and stuff is kind of a waste. Especially if you are just backing them up every so often. I would recommend a 1tb WD Blue HDD for about $50. As for size, not sure on that. :)
Zachary_Baird01
Commendable
May 2, 2016
Ok, thanks alot :D
gumbob3
Respectable
Mar 5, 2016
410
20
No problem, any more questions feel free to ask.
Similar threads
