Hello i need help with my gpu gtx 770
Jul 5, 2018
14
so when i am playing games for example Gta v pubg csgo it crashes at any momment for pubg when i turn it on instant crash in gta v instant crash in csgo instant crash sometimes i can play for like 5 minutes and crash. so the crashes are like this my gpu fan speed goes up to 100% screen goes black says no signal and makes really loud sounds.
SPECS
GPU:gtx 770 2gb
CPU:i5-4430
RAM:32gb 4X8 800mhz
PSU:Corsair vengeance 650W
Motherboard:Z91 Gaming
please help me fix it i cant play almost anything. I have this pc for over 1 year Also temperatures at idle are 30C-40C while playing games 50C-80C
Hey thanks for the answer but when i reboot should i be in safe mode or normal mode to install the drivers again?
I tried it did not help at all, do you have any more solutions?
Is this problem a recent one? If so, please tell us the last thing you updated or changed on your computer or operating system.
There is a possibility you have a virus, some of them are nasty. If you do not have a 3rd party program try one that has a 30 day trial period before you have to purchase or delete it from your computer. https://www.top10bestantivirus.com/free-antivirus-software Note that information at that site is not all inclusive VIPRE is probably the easiest program to use and utilizes very low resources. https://www.vipre.com/
To make sure your CPU power draw and temperature are within perimeters download and install HWiNFO64, if you are using a 64 bit operating system https://www.hwinfo.com/download.php It automatically picks up Windows 32 and 64 bit if you click on the green DOWNLOAD INSTALLER button and download that. I think the download is less than 5MB, a small file. If you have Windows 10 and have questions, right click on the Start button then left System.
You need to do this quickly because your computer or one or more components may fail if you have a hardware problem, which I will discuss once you download and run the above program.
To find CPU temperatures, go to the first CPU listing showing temperatures.
To find voltages go to the first motherboard listing.
If temperatures and voltages are within specification and you have no virus then you have a hardware problem that needs corrected immediately, so, please contact us quickly
i install windows 10 a week ago i dont have any viruses + i have antivirus my cpu is not a problem cpu temp is always 30-50C idle-gaming
i downloaded the program u told me to download oh and also this problem isnt a recent one i have this problem for a year but i dont understand what to do in the program
