Hello, im trying to plug in 3 pin case fans to 4 pin fan motherboard
nopopup
16
my motherboard is gigabyte z77x ud3h and case is antec 300. im trying to plugin top fan and rear fan of the case but they have 3 pin connectors. on the other hand motherboard has 4 pins. Still, i can plug them in. would it be ok?
It should be fine.
My gigabyte 990FX-UD3 automatically recognized that I had a 3-pin fan plugged into the 4-pin CPU header and switched to voltage adjustment.
Just line up the "slot" when you plug the fan in.
It should be fine.
