Hello is the ASRock H110M-DGS motherboard compatible with my Coolermaster G650M Power supply?
Joshua_1226
Commendable
Sep 17, 2016
16
Hello,
This is the first ever computer I have ever built and everything was going well until the end. I tried to turn on the computer but it did not turn on, I asked around and many people are saying it is because my motherboard is not compatible with my power supply. Can anyone please help this is frustrating :/
Thank you!
Josh
If your not comfortable doing this, don't, but if your power button doesn't work you can remove itsome plug from the motherboard, amd short the 2 pins it occupied with a flat tip screwdriver. I've done it many times and it's not uncommon for a switch to be faulty.
My system won't even turn on :/ I pressed the on button and nothing happens :/
I connected the LED lights and everything I needed that the case gave me to the motherboard but I don't know if I have to specifically find the front IO connectors and connect it to the motherboard. Should I try?
It is still not working i rewired the front of the IO but it still will not turn on 🙁
My 24 pin into the motherboard is plugged in, sorry if I sound uneducated but where are my 4 pin for CPU and 6 pin GPU. I have a 8 pin that I have plugged in that is right on top of my CPU is that the 4 pin you were talking about?
I have the Sapphire Radeon RX and it is a 8 pin side as well both plugged in
My Cpu plug is straight up 8 it is not separated by 4+4 and the saphire has been connected by the 6+2
