Alrighty. so to start off, I'm 16 and I have 10 and a half years of experience along with a father who's been working in the tech field for 17 years. I am building my first gaming PC and I know the cores, the only thing I'm not completely sure of is how exactly it'll all fit together and what parts to get. "Not too good with getting parts that are compatible with each other,"
So to sum it up, I need to know what parts I can fit in this tower. I have a brand new CM storm trooper full tower with the glass window.
I'm looking at getting a GTX 980 or a GTX 970, 1000w Power supply "Not sure which one to get yet, or if this is a little to high in watts for my build" 16 gb of ram, "I already have this and 3 terabyte hard drives" an AMD CPU " Not sure which one" And a motherboard which I am not sure of as well..
What parts do you recommend changing and getting? I'm really stuck, I'm willing to spend up to 1500$ right now "I can get this all pretty cheap, around 1300$ for everything I listed so far. But Any suggestions are fine and I'm down to go for a 1500 to 2000$ build depending on how much I can build onto it,"
Please. serious answers only, I just really want to know what I need and what I can fit in this CM storm trooper. "And no, I'm not doing water cooled unless I absolutely have too, I'm in colorado so it's not too hot and not hard to keep a PC cool"
PS: I'm looking to play Gta 5 maxed, fallout 4 maxed, and that's what wll be good for me for a couple years, not looking to go too big. So if I can dim down on the parts a bit and get something good enough for cheap enough, let me know! Suggestions for monitors, keyboards, and mouses are welcome!
Thanks!
Thanks!
