HELP: 0033 Error code GeForce GT730
budgy
210
I have an AMD X4 Phenom 965 Black edition.
My motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
New graphics card I just installed:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133542
My computer won't even let me in BIOS or do a POST. When I turn the computer on, the top left side displays the model and type of video card I just installed; then a brief millisecond on the bottom right it says 0033. Then the screen goes blank.
I've googled this and no one knows what this means. Does anyone on Tom's hardware know what it means? Thanks.
ASRock M3A770DE AM3
I think the 0033 just means 'video'
You can also try attaching an internal speaker (eg http://www.amazon.com/PC-Internal-Mini-Onboard-Speaker/dp/B002W4M0DW) to your motherboard (per the manual) and seeing what post/beep code you get per http://www.computerhope.com/beep.htm
It might give you more clues.
Post your build in detail.
Try another monitor cable.
Try another monitor.
Try another graphics card.
budgy
210
Problem solved.
I put the old video card back and I went into BIOS. I set it from PCI to PCIe selection. NOw it's working.
