Question Help! 1080 TI not running to its full potential!
Mar 11, 2019
6
Hi Guys!
I have been using a 1080ti for about 3 months now and i feel it has not been using its full potential. Could be some parts of my rig that is not pulling its weight. I can't get decent 60 fps framerate with modern AAA games on Ultra or even High. Below is a LONG list of my spec and userbenchmark results.
Kindly advise on what i can do to improve on!
Many Thanks!
(https://www.userbenchmark.com/UserRun/15386185)
||Model|Bench
CPU|(https://cpu.userbenchmark.com/Intel-Core-i7-8700/Rating/3940)|98.6%
GPU|(https://gpu.userbenchmark.com/Nvidia-GTX-1080-Ti/Rating/3918)|150.9%
SSD|(https://ssd.userbenchmark.com/OCZ-ARC-100-120GB/Rating/3487)|72.1%
SSD|(https://ssd.userbenchmark.com/Crucial-MX100-128GB/Rating/2618)|78.1%
HDD|(https://hdd.userbenchmark.com/Toshiba-DT01ACA100-1TB/Rating/2737)|64.8%
HDD|(https://hdd.userbenchmark.com/Toshiba-P300-1TB/Rating/3589)|49.6%
RAM|(https://ram.userbenchmark.com/SpeedTest/499613/V02D4L84GB5285282400-4x4GB)|74.8%
MBD|(https://www.userbenchmark.com/System/Asus-PRIME-Z370-P/67487)|
Summary
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i7 @ 3.20GHz 43 °C
Coffee Lake 14nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1202MHz (17-17-17-39)
Motherboard
ASUSTeK COMPUTER INC. PRIME Z370-P (LGA1151) 34 °C
Graphics
ZOWIE XL LCD (2560x1440@144Hz)
3071MB NVIDIA GeForce GTX 1080 Ti (ZOTAC International) 65 °C
Storage
931GB TOSHIBA DT01ACA100 (SATA ) 38 °C
119GB Crucial_CT128MX100SSD1 (SATA (SSD)) 33 °C
111GB OCZ-ARC100 (SATA (SSD))
931GB TOSHIBA HDWD110 (SATA ) 37 °C
CPU
Intel Core i7
Cores 6
Threads 12
Name Intel Core i7
Code Name Coffee Lake
Package Socket 1151 LGA
Technology 14nm
Specification Intel Core i7-8700 CPU @ 3.20GHz
Family 6
Extended Family 6
Model E
Extended Model 9E
Stepping A
Revision U0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3
Virtualization Supported, Disabled
Hyperthreading Supported, Enabled
Bus Speed 100.2 MHz
Stock Core Speed 3200 MHz
Stock Bus Speed 100 MHz
Average Temperature 43 °C
Caches
L1 Data Cache Size 6 x 32 KBytes
L1 Instructions Cache Size 6 x 32 KBytes
L2 Unified Cache Size 6 x 256 KBytes
L3 Unified Cache Size 12288 KBytes
Cores
Core 0
Core Speed 4310.5 MHz
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Threads APIC ID: 0, 1
Core 1
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 45 °C
Threads APIC ID: 2, 3
Core 2
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Threads APIC ID: 4, 5
Core 3
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Threads APIC ID: 6, 7
Core 4
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Threads APIC ID: 8, 9
Core 5
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Threads APIC ID: 10, 11
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type Unknown
Size 16384 MBytes
Channels # Dual
DRAM Frequency 1203.0 MHz
CAS# Latency (CL) 17 clocks
RAS# to CAS# Delay (tRCD) 17 clocks
RAS# Precharge (tRP) 17 clocks
Cycle Time (tRAS) 39 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 41 %
Total Physical 16 GB
Available Physical 9.39 GB
Total Virtual 35 GB
Available Virtual 25 GB
SPD
Number Of SPD Modules 4
Slot #1
Type Unknown
Size 4096 MBytes
Manufacturer Unknown
Max Bandwidth DDR4-2400 (1200 MHz)
Part Number V02D4L84GB52852824
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
Frequency 1018.2 MHz
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
Frequency 1090.9 MHz
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
Frequency 1163.6 MHz
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
Frequency 1200.5 MHz
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #2
Type Unknown
Size 4096 MBytes
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #3
Type Unknown
Size 4096 MBytes
Week/year 28 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #4
Type Unknown
Size 4096 MBytes
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model PRIME Z370-P (LGA1151)
Version Rev X.0x
Chipset Vendor Intel
Chipset Model Coffee Lake
Chipset Revision 07
Southbridge Vendor Intel
Southbridge Model Z370
Southbridge Revision 00
System Temperature 34 °C
BIOS
Brand American Megatrends Inc.
Version 0612
Date 3/1/2018
Voltage
+5V 5.040 V
+3.3V 3.360 V
+12V 12.000 V
VIN3 0.848 V
VIN4 0.816 V
VCORE 1.200 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation PCIEX16_1
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Data lanes x16
Slot Designation PCIEX16_2
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Designation PCIEX1_1
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Designation PCIEX1_2
Slot Number 3
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Designation PCIEX1_3
Slot Number 4
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Designation PCIEX1_4
Slot Number 5
Graphics
Monitor
Name ZOWIE XL LCD on NVIDIA GeForce GTX 1080 Ti
Current Resolution 2560x1440 pixels
Work Resolution 2560x1400 pixels
State Enabled, Primary
Monitor Width 2560
Monitor Height 1440
Monitor BPP 32 bits per pixel
Monitor Frequency 144 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer NVIDIA
Model GeForce GTX 1080 Ti
Device ID 10DE-1B06
Revision A2
Subvendor ZOTAC International (MCO)/PC Partner (19DA)
Current Performance Level Level 0
Current GPU Clock 1569 MHz
Current Memory Clock 5508 MHz
Current Shader Clock 5508 MHz
Voltage 0.781 V
Technology 16 nm
Bus Interface PCI Express x1
Temperature 65 °C
Driver version 25.21.14.1917
BIOS Version 86.02.39.00.73
Physical Memory 3071 MB
Virtual Memory 3072 MB
Count of performance levels : 1
Level 1 - "Perf Level 0"
GPU Clock 1569 MHz
Storage
Hard drives
TOSHIBA DT01ACA100
Manufacturer TOSHIBA
Heads 16
Cylinders 121,601
Tracks 31,008,255
Sectors 1,953,520,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number Y639L1UFS
Firmware Version Number MS2OA750
LBA Size 48-bit LBA
Power On Count 1146 times
Power On Time 309.1 days
Speed 7200 RPM
Features S.M.A.R.T., APM, NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA III 6.0Gb/s
Interface SATA
Capacity 931 GB
Real size 1,000,204,886,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 38 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
01
Attribute name Read Error Rate
Real value 0
Current 100
Worst 100
Threshold 16
Raw Value 0000000001
Status Good
02
Attribute name Throughput Performance
Real value 68
Current 142
Worst 142
Threshold 54
Raw Value 0000000044
Status Good
03
Attribute name Spin-Up Time
Real value 11993271 ms
Current 125
Worst 125
Threshold 24
Raw Value 0000B700B7
Status Good
04
Attribute name Start/Stop Count
Real value 1,168
Current 100
Worst 100
Threshold 0
Raw Value 0000000490
Status Good
05
Attribute name Reallocated Sectors Count
Real value 0
Current 100
Worst 100
Threshold 5
Raw Value 0000000000
Status Good
07
Attribute name Seek Error Rate
Real value 0
Current 100
Worst 100
Threshold 67
Status Good
08
Attribute name Seek Time Performance
Real value 34
Current 115
Worst 115
Threshold 20
Raw Value 0000000022
Status Good
09
Attribute name Power-On Hours (POH)
Real value 309d 2h
Current 99
Worst 99
Threshold 0
Raw Value 0000001CFA
Status Good
0A
Attribute name Spin Retry Count
Real value 0
Current 100
Worst 100
Threshold 60
Status Good
0C
Attribute name Device Power Cycle Count
Real value 1,146
Current 100
Worst 100
Threshold 0
Raw Value 000000047A
Status Good
C0
Attribute name Power-off Retract Count
Real value 6,009
Current 95
Worst 95
Threshold 0
Raw Value 0000001779
Status Good
C1
Attribute name Load/Unload Cycle Count
Real value 6,009
Current 95
Worst 95
Threshold 0
Status Good
C2
Attribute name Temperature
Real value 38 °C
Current 157
Worst 157
Threshold 0
Raw Value 0000160026
Status Good
C4
Attribute name Reallocation Event Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Attribute name Current Pending Sector Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Attribute name Uncorrectable Sector Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Attribute name UltraDMA CRC Error Count
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number 5CD2055B
Size 931 GB
Used Space 755 GB (81%)
Free Space 175 GB (19%)
Crucial_CT128MX100SSD1 (SSD)
Heads 16
Cylinders 15,566
Tracks 3,969,330
Sectors 250,067,790
Device type Fixed
ATA Standard ACS2
Serial Number 14340D056E3A
Firmware Version Number MU01
LBA Size 48-bit LBA
Power On Count 1147 times
Power On Time 5.1 days
Speed Not used (SSD Drive)
Features S.M.A.R.T., APM, NCQ, TRIM, SSD
Interface SATA
Capacity 119 GB
Real size 128,035,676,160 bytes
RAID Type None
S.M.A.R.T
Status Unknown
Temperature 33 °C
01
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
05
Attribute name Retired Block Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
09
Real value 5d 3h
Current 100
Worst 100
Threshold 0
Raw Value 000000007B
Status Good
0C
Real value 1,147
Current 100
Worst 100
Threshold 0
Raw Value 000000047B
Status Good
AB
Attribute name Program Fail Block Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
AC
Attribute name Erase Fail Block Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
AD
Attribute name Wear Leveling Count
Real value 6
Current 100
Worst 100
Threshold 0
Raw Value 0000000006
Status Good
AE
Attribute name Unexpected Power Loss
Real value 399
Current 100
Worst 100
Threshold 0
Raw Value 000000018F
Status Good
B4
Attribute name Reserved Block Count
Real value 1,036
Current 0
Worst 0
Threshold 0
Raw Value 000000040C
Status Good
B7
Attribute name SATA Downshift Error Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Attribute name Reported I/O Error Detection Code Rate
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BB
Attribute name Reported Uncorrectable Errors
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C2
Real value 33 °C
Current 67
Worst 53
Threshold 0
Raw Value 0000160021
Status Good
C4
Real value 16
Current 100
Worst 100
Threshold 0
Raw Value 0000000010
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Attribute name SATA R-Errors (CRC) Error Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
CA
Attribute name Data Address Mark errors
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
CE
Attribute name Flying Height
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
D2
Attribute name Vibration During Write
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter E:
File System NTFS
Volume Serial Number F0430893
Size 119 GB
Used Space 81 GB (68%)
Free Space 37.9 GB (32%)
OCZ-ARC100 (SSD)
Manufacturer OCZ
Heads 16
Cylinders 14,593
Tracks 3,721,215
Sectors 234,436,545
Device type Fixed
Serial Number A22L0061544001985
Firmware Version Number 1.01
LBA Size 48-bit LBA
Power On Count 1673 times
Power On Time 421.4 days
Features S.M.A.R.T., NCQ, TRIM, SSD
Interface SATA
Capacity 111 GB
Real size 120,034,123,776 bytes
RAID Type None
S.M.A.R.T
Status Good
05
Attribute name Accumulated runtime bad blocks
Real value 0
Current 0
Worst 0
Threshold 0
Status Good
09
Real value 421d 9h
Current 100
Worst 100
Threshold 0
Raw Value 0000002781
Status Good
0C
Real value 1,673
Current 100
Worst 100
Threshold 0
Raw Value 0000000689
Status Good
AB
Attribute name Available OP block count
Real value 42,005,584
Current 100
Worst 100
Threshold 0
Raw Value 000280F450
Status Good
AE
Attribute name Power Cycle Count (unplanned)
Real value 165
Current 100
Worst 100
Threshold 0
Raw Value 00000000A5
Status Good
C3
Attribute name Total programming failures
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C4
Attribute name Total Erase Failures
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Attribute name Total read failures (uncorrectable)
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
D0
Attribute name Average Erase Count
Real value 426
Current 100
Worst 100
Threshold 0
Raw Value 00000001AA
Status Good
D2
Attribute name SATA CRC error count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
E0
Attribute name Load Friction
Real value 1
Current 100
Worst 100
Threshold 0
Status Good
E9
Attribute name Lifetime remaining
Real value 86
Current 86
Worst 86
Threshold 0
Raw Value 0000000056
Status Good
F1
Attribute name Host writes (GB)
Real value 10,207
Current 100
Worst 100
Threshold 0
Raw Value 00000027DF
Status Good
F2
Attribute name Host reads (GB)
Real value 11,312
Current 100
Worst 100
Threshold 0
Raw Value 0000002C30
Status Good
F9
Attribute name Total NAND programming count (GB)
Real value 667,755,836
Current 100
Worst 100
Threshold 0
Raw Value 0027CD253C
Status Good
Partition 0
Partition ID Disk #2, Partition #0
File System NTFS
Volume Serial Number A8520335
Size 299 MB
Used Space 12.8 MB (4%)
Free Space 287 MB (96%)
Partition 1
Partition ID Disk #2, Partition #1
File System FAT32
Volume Serial Number 7654128B
Size 96 MB
Used Space 25.4 MB (26%)
Free Space 70 MB (74%)
Partition 2
Partition ID Disk #2, Partition #2
Disk Letter C:
File System NTFS
Volume Serial Number 1E5698A8
Size 110 GB
Used Space 101 GB (91%)
Free Space 9.03 GB (9%)
Partition 3
Partition ID Disk #2, Partition #3
File System NTFS
Volume Serial Number 76A7B3BB
Size 477 MB
Used Space 428 MB (89%)
Free Space 49 MB (11%)
TOSHIBA HDWD110
Heads 16
Cylinders 121,601
Tracks 31,008,255
Device type Fixed
Serial Number 489PDV1MS
Firmware Version Number MS2OA8R0
LBA Size 48-bit LBA
Power On Count 324 times
Power On Time 97.2 days
Speed 7200 RPM
Interface SATA
Capacity 931 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
01
Real value 0
Current 100
Worst 100
Threshold 16
Status Good
02
Real value 68
Current 142
Worst 142
Threshold 54
Status Good
03
Real value 11796660 ms
Current 127
Worst 127
Threshold 24
Raw Value 0000B400B4
Status Good
04
Real value 1,463
Current 100
Worst 100
Threshold 0
Raw Value 00000005B7
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 5
Status Good
07
Real value 0
Current 100
Worst 100
Threshold 67
Status Good
08
Real value 37
Current 108
Worst 108
Threshold 20
Raw Value 0000000025
Status Good
09
Real value 97d 5h
Current 100
Worst 100
Threshold 0
Raw Value 000000091D
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 60
Status Good
0C
Real value 324
Current 100
Worst 100
Threshold 0
Raw Value 0000000144
Status Good
C0
Real value 4,822
Current 96
Worst 96
Threshold 0
Raw Value 00000012D6
Status Good
C1
Real value 4,822
Current 96
Worst 96
Threshold 0
Status Good
C2
Real value 37 °C
Current 162
Worst 162
Threshold 0
Raw Value 0000160025
Status Good
C4
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
Partition 0
Partition ID Disk #3, Partition #0
Disk Letter F:
File System NTFS
Volume Serial Number D28E8958
Size 931 GB
Used Space 664 GB (71%)
Free Space 266 GB (29%)
Optical Drives
Apologies, new to this forum. Pls explains 🙁
Family 6
Extended Family 6
Model E
Extended Model 9E
Stepping A
Revision U0
Bus Speed 100.2 MHz
Caches
Cores
Core 0
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Core 1
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 45 °C
Core 2
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Core 3
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Core 4
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
Core 5
Multiplier x 43.0
Bus Speed 100.2 MHz
Temperature 43 °C
RAM
Memory slots
Used memory slots 4
Free memory slots 0
Memory
Type Unknown
Size 16384 MBytes
Channels # Dual
Physical Memory
Memory Usage 41 %
Total Virtual 35 GB
SPD
Slot #1
Type Unknown
Size 4096 MBytes
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #2
Type Unknown
Size 4096 MBytes
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #3
Type Unknown
Size 4096 MBytes
Week/year 28 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Slot #4
Type Unknown
Size 4096 MBytes
Week/year 29 / 18
Timing table
JEDEC #1
Frequency 727.3 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 24
tRC 34
Voltage 1.200 V
JEDEC #2
Frequency 800.0 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 26
tRC 37
Voltage 1.200 V
JEDEC #3
Frequency 872.7 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 28
tRC 40
Voltage 1.200 V
JEDEC #4
Frequency 945.5 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 31
tRC 44
Voltage 1.200 V
JEDEC #5
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 33
tRC 47
Voltage 1.200 V
JEDEC #6
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 35
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 16
RAS# Precharge 16
tRAS 38
tRC 54
Voltage 1.200 V
JEDEC #8
CAS# Latency 17.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #9
CAS# Latency 18.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #10
CAS# Latency 19.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #11
CAS# Latency 20.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
JEDEC #12
CAS# Latency 21.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 39
tRC 55
Voltage 1.200 V
Motherboard
Version Rev X.0x
Chipset Revision 07
BIOS
Version 0612
Date 3/1/2018
Voltage
+5V 5.040 V
+3.3V 3.360 V
+12V 12.000 V
VIN3 0.848 V
VIN4 0.816 V
VCORE 1.200 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Data lanes x16
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Number 3
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Number 4
Slot PCI-E
Slot Type PCI-E
Data lanes x1
Slot Number 5
Graphics
Monitor
Monitor Width 2560
Monitor Height 1440
Manufacturer NVIDIA
Device ID 10DE-1B06
Revision A2
Voltage 0.781 V
Technology 16 nm
Temperature 65 °C
GPU Clock 1569 MHz
Storage
Hard drives
TOSHIBA DT01ACA100
Heads 16
Cylinders 121,601
Tracks 31,008,255
Device type Fixed
LBA Size 48-bit LBA
Speed 7200 RPM
Interface SATA
Capacity 931 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 38 °C
01
Real value 0
Current 100
Worst 100
Threshold 16
Status Good
02
Real value 68
Current 142
Worst 142
Threshold 54
Status Good
03
Current 125
Worst 125
Threshold 24
Status Good
04
Real value 1,168
Current 100
Worst 100
Threshold 0
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 5
Status Good
07
Real value 0
Current 100
Worst 100
Threshold 67
Status Good
08
Real value 34
Current 115
Worst 115
Threshold 20
Status Good
09
Real value 309d 2h
Current 99
Worst 99
Threshold 0
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 60
Status Good
0C
Real value 1,146
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 6,009
Current 95
Worst 95
Threshold 0
Status Good
C1
Real value 6,009
Current 95
Worst 95
Threshold 0
Status Good
C2
Real value 38 °C
Current 157
Worst 157
Threshold 0
Status Good
C4
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
Partition 0
Disk Letter D:
File System NTFS
Size 931 GB
Heads 16
Cylinders 15,566
Tracks 3,969,330
Sectors 250,067,790
Device type Fixed
ATA Standard ACS2
LBA Size 48-bit LBA
Interface SATA
Capacity 119 GB
RAID Type None
S.M.A.R.T
Status Unknown
Temperature 33 °C
01
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
09
Real value 5d 3h
Current 100
Worst 100
Threshold 0
Status Good
0C
Real value 1,147
Current 100
Worst 100
Threshold 0
Status Good
AB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
AC
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
AD
Real value 6
Current 100
Worst 100
Threshold 0
Status Good
AE
Real value 399
Current 100
Worst 100
Threshold 0
Status Good
B4
Real value 1,036
Current 0
Worst 0
Threshold 0
Status Good
B7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C2
Real value 33 °C
Current 67
Worst 53
Threshold 0
Status Good
C4
Real value 16
Current 100
Worst 100
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
CA
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
CE
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
D2
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
Partition 0
Disk Letter E:
File System NTFS
Size 119 GB
OCZ-ARC100 (SSD)
Manufacturer OCZ
Heads 16
Cylinders 14,593
Tracks 3,721,215
Sectors 234,436,545
Device type Fixed
LBA Size 48-bit LBA
Interface SATA
Capacity 111 GB
RAID Type None
S.M.A.R.T
Status Good
05
Real value 0
Current 0
Worst 0
Threshold 0
Status Good
09
Real value 421d 9h
Current 100
Worst 100
Threshold 0
Status Good
0C
Real value 1,673
Current 100
Worst 100
Threshold 0
Status Good
AB
Current 100
Worst 100
Threshold 0
Status Good
AE
Real value 165
Current 100
Worst 100
Threshold 0
Status Good
C3
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C4
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
D0
Real value 426
Current 100
Worst 100
Threshold 0
Status Good
D2
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
E0
Real value 1
Current 100
Worst 100
Threshold 0
Status Good
E9
Real value 86
Current 86
Worst 86
Threshold 0
Status Good
F1
Real value 10,207
Current 100
Worst 100
Threshold 0
Status Good
F2
Real value 11,312
Current 100
Worst 100
Threshold 0
Status Good
F9
Current 100
Worst 100
Threshold 0
Status Good
Partition 0
File System NTFS
Size 299 MB
Partition 1
File System FAT32
Size 96 MB
Partition 2
Disk Letter C:
File System NTFS
Size 110 GB
Partition 3
File System NTFS
Size 477 MB
TOSHIBA HDWD110
Heads 16
Cylinders 121,601
Tracks 31,008,255
Device type Fixed
LBA Size 48-bit LBA
Speed 7200 RPM
Interface SATA
Capacity 931 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
01
Real value 0
Current 100
Worst 100
Threshold 16
Status Good
02
Real value 68
Current 142
Worst 142
Threshold 54
Status Good
03
Current 127
Worst 127
Threshold 24
Status Good
04
Real value 1,463
Current 100
Worst 100
Threshold 0
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 5
Status Good
07
Real value 0
Current 100
Worst 100
Threshold 67
Status Good
08
Real value 37
Current 108
Worst 108
Threshold 20
Status Good
09
Real value 97d 5h
Current 100
Worst 100
Threshold 0
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 60
Status Good
0C
Real value 324
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 4,822
Current 96
Worst 96
Threshold 0
Status Good
C1
Real value 4,822
Current 96
Worst 96
Threshold 0
Status Good
C2
Real value 37 °C
Current 162
Worst 162
Threshold 0
Status Good
C4
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
Partition 0
Disk Letter F:
File System NTFS
Size 931 GB
Optical Drives
here is your problem:
The PC only sees 3 GB out of 11 or 12 that your GPU should have.
It's either a connection issue, PSU issue or even warranty.
Thank you Andrei. Where would you suggest me looking into first? Should i re-seat my power supply to my GPU ?
