So if I understand, you have a 120 on the front for the intake and a 120 on the rear as the exhaust.
Yep. That be right.
IF this is correct, then see what reversing the two fans will do to the temps. This drops my temps by another 4-5 degrees. It will depend somewhat on where the fans are mounted but this is what I think that makes this work better.
Wouldn't you have to reverse the fan in the power supply as well? Not that I couldn't, but that'd kill its warranty.
Still, it is an intriguing concept. I can see the advantage. I'm just not sure that the Antec Sonata case would take to it very well. In Sonata the 'front' fan is actually mounted in the middle of the case behind the hard drive cage, which would limit my exhaust. On top of the intake isn't so great in the standard configuration. It relies a little more than my liking on the side vents. So one would think then that reversing the fans would leave the intake strong but the exhaust very weak. Wouldn't that leave a lot of hot air in the case then?
I think I'd rather prefer to mod the case according to a plan I've had for a while now. I can put some intake holes into the front door, slice up the free floppy bay cover into a filter, and mount the 'front' fan's bottom two holes to the top two of the fan mount to shift the front fan to be right between the floppy bay and the CPU.
If I do that it should greatly improve my intake and give the CPU an almost direct cool-air feed from that. It might even be a good enough mod that I could then add sound damping material to the inside of the case and cover up the side vents. There's even a pre-cut kit made for the Sonata.
Of course I'll probably go to the fanless heatsink before I put in damping material. In fact, if I can get away with covering the side panel intakes I'll probably refresh my electrical engineering skills with a little LED project to fill LEDs into the side panel gaps. (Which, as the vents are holed to spell out Antec, it should look pretty neat.) Maybe I'll even try to make the LED controller programmable through a USB connection. Then I'll put the damping material over that. So really, the damping material comes last in my priorities.
But if I can manage all of that then it would be interesting to see what kind of OC I could manage on such a quiet PC. I wouldn't expect much of an OC, but then again, it is a NWC. I probably should have gone with the 2.4 instead of the 2.6 though since heat will probably give me a ceiling before the proc does. Oh well. Maybe I'll get lucky. And maybe I'll afford to do this and have it all done by ... oh ... 2007. :\
<pre>Antec Sonata 2x120mm
P4C 2.6
Asus P4P800Dlx
2x512MB CorsairXMS3200C2
Leadtek A6600GT TDH
RAID1 2xHitachi 40GB
BENQ 16X DVD+/-RW
Altec Lansing 251
NEC FE990 19"CRT</pre><p>
