Question Help 24 pin
Assuming you're referring to a motherboard connector from a PSU, that's common; the -5V and -12V aren't really used anymore, and they're only there for compatibility with ancient hardware. The -5V rail was removed from ATX spec like 20 years ago and -12V probably will be at some point; IIRC it was used with serial ports.
Reactions: CountMike
