Archived from groups: alt.comp.periphs.dcameras (
More info?)
thx for ur input guys
"John@Smith.com" <xxxxspud@newscene.com> wrote in message
news:ce5jr05ta69qadr59agpibsc2c8htnqddf@4ax.com...
> On Thu, 09 Dec 2004 23:53:46 GMT, "Robert Jackson"
> <rabramson1@si.rr.com> wrote:
>>what is the best digital camera (quality-wise and battery life) would u
>>recommend under 300 bucks?
>>thanks,
>>rob
> Man thats tough right now cause there are tons of ongoing sales now
> with Xmas closing in. It would be a virtual week by week things.
> In the past people would say Canon a lot because they produced good
> pics and had some manual controls . However I did see a few people
> posting on Amazon about certain problems people have with some Canons
> which they were pissed about but then you see that with a vareity of
> cameras since digital cameras can be fragile.
> Imaging resource has the most straight forward picks in each category
http://www.imaging-resource.com/WB/WB.HTM?view=range2
> Then look at the same site for the full detailed review
http://www.imaging-resource.com/INDEX.HTM
> They mention the Canon A85 under 300 as well as others.
> If you want a big zoom - theres the oly 740 they mention actually
> these are being discounted as I mentioned so you might get a much
> better oly big zoom for cheap. I got the 750 for 199 a while ago 10x
> optical zoom.
> The avg camera has 3x optical zoom around there. It all depends on
> taste too. You might not need big zooms and some like soapbar , small
> point and shoot cameras where others want more manual controls.
> They also mention the C-5000 olympus - Ive got the 4040 and and Olys
> in the past have been particularly good at least this series , at
> lowlight pics which many lower and mid range digi cams werent good at.
> They tend to be a bit bulkier than the soapbar cameras that you can
> fit inyour pants jacket pocket but not quite as big in the lens area
> as the big zooms.
> I also bought an Oly soapbar camera for my father and one thing about
> the OLYs they use XD cards which tend to be much more expensive than
> the SD and compact flash cards which sell often for peanuts now with
> rebates. THe xds are finally coming down a bit but still much more
> expensive.
> So you have some you can add stuff onto - lenses, flash units and
> others you cant - namely all of the soapbar type point and shoot
> cameras . Some are better than others at low light shots etc .
> You can see additional tests at www.megapixel.net
http://www.dcresource.com/reviews/cameraList.php
http://www.steves-digicams.com/hardware_reviews.html
> http://www.dpreview.com/
