Help! 32g micro SD card
nikkimiles1970
I have purchased a brand new Galaxy Ace phone (not really technical) and a 32g SD card and I can't get my SD card to allow me to download anything.
Please explain in layman's terms what I can do TIA
Which phone specifically? The original Ace? Ace2? Ace3? Ace4?
What are you trying to download? What size are the file(s)?
At worst, you're running a 6-7 year old phone (Ace) Gingerbread (2.3.6), at best, it's JellyBean (4.2.2) or KitKat (4.4.2), a 3-4 year old phone (Ace4)
Prior to Android6.0, you cannot use the SD as "internal" storage, as that feature didn't come until much later than Gingerbread. What you need to be able to do on an older phone like that is download X file to the internal storage of the phone, then move it to the SD card.
If you're looking at the original Ace, it only had 512MB (1/2 GB) of storage, total. Available to the user is more like 180MB (<0.2GB), and that's before you install apps etc...
If you're looking at the original Ace, it only had 512MB (1/2 GB) of storage, total. Available to the user is more like 180MB (<0.2GB), and that's before you install apps etc. Chances are, if running the original Ace, you simply have no room to download anything to the phone itself, and cannot download directly to the SD card.
Even 3 years is a lifetime in phone technology developments and, if you're talking the original Ace at 6-7 years old, I'd be surprised if it let you do much at all.
