Just received my a gigabyte 4090 wind force and got it installed. Unfortunately after install this GPU is giving me a nightmare that I did not expect from such an expensive piece of hardware. When I power the pc on with a display port I am getting no image or anything at all. I tried using a HDMI cable and finally got the pc to post. Works great with hdmi played some games and working as designed. It’s super strange because when it does post with a hdmi cable it black screens for 5 minutes then comes on. I did some research and performed the UEFI firmware update with Nvidia but still having the same issue. Also I tried changing the mother board bios from the most current version to the prior with no change in issue. Tried re seating the card and even switch the bios on the card from oc to quite and nothing seems to be fixing this. Any insight on this issue would be greatly appreciated!
System specs
AMD 5800X3D processor
MSI x 570 a pro motherboard
16gb patriot viper ddr4 4200 ram
Gigabyte 4090 wind force
Windows 10
EVGA 850 power supply
System specs
Windows 10
