help $500 build
nmdride
50
Approximate Purchase Date: January 1st
Budget Range: $500 Total (maybe $550)
System Usage from Most to Least Important: Movies, Internet, Light Gaming (Cs 1.6, css, l4d)
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: Newegg
Country of Origin: USA
Parts Preferences: AMD CPU
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1024x768
Additional Comments: windows 7 premium
reaper2794
808
Reason no one replied is most likely cause of your budget..
1/5th of it is gonna go to the OS alone and that's not even the one you want
Go get 800+ and then you can get a decent computer, 500 will be a waste on weak outdated parts
Here's an idea, I'll try again tomorrow.
BIOSTAR A880G+ AM3 + Microsoft Windows 7 Home Premium 64-bit
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.552638
AMD Athlon II X3 450 + GIGABYTE GV-R577SO-1GD Radeon HD 5770
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.544487
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231396
LG Black 22X DVD+R
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136168
Seagate Barracuda 7200.12 + HEC 6K28BBX585 Black 0.8mm SECC Steel MicroATX Mini Tower Computer Case 585W Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.543386
$531.92
GIGABYTE GA-880GA-UD3H + Microsoft Windows 7 Home Premium 64-bit
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.552609
AMD Athlon II X3 445 + Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR3
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.555635
SAMSUNG Spinpoint F3 HD502HJ 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Antec NEO ECO 400C 400W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371029
LG DVD Burner - Bulk Black SATA + HEC Blitz Black Steel Edition
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.542984
$495.42
bigger HDD
SAMSUNG Spinpoint F3 HD103SJ 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
X3 + 4GB DDR3 + 80+ certified PSU with a GTS 450?
$495AR
