There is no viable upgrade path for FM2 system.which CPU would be a good match? And would any additional upgrades be necessary if those 2 are made? Thanks in advance
[/QUOTE]Yes, 1660. Would upgrading the GPU only, produce any noticeable difference,95 watt power supply.? Thank you and sorry for my computer illiteracy. I am not sure what he trying to achieve ,maybe faster or smoother.
As far as CPU goes, there's nothing on the socket that would be a worthwhile 'upgrade', which would necessitate a Motherboard/RAM upgrade also, unfortunately.
What PSU is powering the setup?
What is it you're trying to achieve with the upgrade?
I appreciate all the help. Here is what the computer now has.
485W HP485DB
GTX1050
Hi Fi A70U3P Motherboard
DDR3 8GB Mem.
AMD ATHLON X4v845
So, seeing this info. if he wants better performing computer , we should follow some of the previous advice and do a complete rebuild? Thanks
Yes !So, seeing this info. if he wants better performing computer , we should follow some of the previous advice and do a complete rebuild? Thanks
This one is decent:Is there a step by step video you can recommend that we can watch to help complete the rebuild?
