Help a poor man out :P
Damien324
31
So i got told recently that my cpu is running hot which is causing my games to freeze (sounds keep playing in the background until i crt alt dlt then the game works again)
So when the games freeze i always notice that in the task manager my cpu is running at a 100% (Only when they freeze when the game unfreezes it sits back down to 20-30%)
So what is it thats the question is it high cpu temps or something eles?
The image is just idle temps
And i have an aftermarket $10 cooler.
The gamaxx 300 is a half decent budget cooler.
Those temps for idle are incredibly high though mate - if 52c is the lowest its been then you're no doubt hitting 70-75c+ underload.
Are you sure its installed correctly?
What's your motherboard model?
Damien324
31
Temps are up mate first post on the screen they don't change much
You running over clocked on the CPU??
Or disabled APM settings in bios??
Just I've never seen a stock chip hit 4.3ghz boost speed on all cores in prime without some tinkering or throttling.
Your idle temps are terrible for some reason ,your load temps are a-ok.
If that's over clocked then your voltage is too low for 4.3ghz on all 8 cores mate .
Either drop the clocks or raise the voltage ,with those temps I would honestly run it at stock.
