Since I upgraded my PC and also went to windows 10 I've been getting BSOD's around 1-2 times per week. My PC also just freezes sometimes, and heat isn't the problem, my CPU sits around 30-40 degrees celsius always. I've tried so many online solutions and read hundreds of forum pages, but I thought I'd just submit my own thread.
WhoCrashed tells me it's most likely driver related but I've tried updating all my drivers. This leads me to believe that possibly my motherboard (ASUS Sabertooth 990FX) is the issue because my drivers are for windows 7 (they offer no windows 10 drivers anymore). I ran memtest86+ a while back and I believe it found nothing concerning.
Relevant PC Specs:
WhoCrashed's analysis of several minidump files:
Thanks for reading, any advice is welcome
Relevant PC Specs:
Motherboard: ASUS Sabertooth 990FX
CPU: AMD FX-9590 (i know i shouldn't have bought this)
CPU Fan: Kraken x61 watercooler
Graphics card: GeForce GTX 970
On Sat 15-Oct-16 4:20:43 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\101516-10546-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14A2C0)
Bugcheck code: 0x1E (0xFFFFFFFF80000003, 0xFFFFF801E0BC6D90, 0x0, 0xFFFFCF845088F6A8)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: kbdhid.sys (kbdhid+0x2F13)
file path: C:\WINDOWS\system32\drivers\kbdhid.sys
description: HID Keyboard Filter Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 15-Oct-16 12:03:49 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\101516-10343-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFF80000003, 0xFFFFF802C1353D90, 0x0, 0xFFFFE286714C03A8)
On Wed 12-Oct-16 7:12:54 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\101216-10031-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14A2B0)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF802037EEE53, 0x0, 0x0)
On Wed 28-Sep-16 6:31:19 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\092816-10359-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14A0B0)
Bugcheck code: 0x1A (0x41792, 0xFFFFF680000C4620, 0x20000000000, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Mon 26-Sep-16 3:53:06 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\092616-9968-01.dmp
Bugcheck code: 0x1A (0x41793, 0xFFFFCC800003AFF8, 0x200, 0x1FF)
