G
Guest
Guest
I've been having issues with my GeForce card not running stable D3D games with the new Detonator drivers under WinXP. I've done some searching and found that it's an issue with my VIA KT-133 chipset (one of many issues I've had with this chipset). I've tried different Detonator versions, newest 4in1 drivers for my chipset.. nothing helped prevent these crashes. So I decided to flash my BIOS from 1008 to 1009 and hope that would fix the problem. I rebooted into DOS and flashed my bios using aflash. After flashing my BIOS I got a message saying "Flashed Successfully". Then I got a message recommending me to turn off the power, enter SETUP and LOAD setup defaults to have CMOS updated with the new BIOS. So I rebooted the system and nothing happened! The power turns on and my cdroms light up but the screen stays blank! No beeps or anything. I've tried shorting the two solder points on my motherboard to reset my CMOS but that didn't seem to work. Is there anythign I can do to fix this problem or anywhere I can bring my motherboard to have this problem fixed? ANy info would be appreciated.
Thanks
Jimmy
Thanks
Jimmy
