hibariokcej22 :
Sorry, I’m having trouble sending a reply to everyone but I do appreciate all of your suggestions.
I’ll check the health of my HDD later once I’m home and will post a screenshot.
Sometimes, after booting to Windows. I can’t click on taskbar and all of the icons looks like a paper. I need to wait for about 5 mins for everything to work.
I think I’ll clone everything from my HDD to the SSHD. I’m planning to do a partition solely for the OS because I was not able to do it on HDD. Can I clone the OS into that partition and after that, clone the programs into another partition? Sorry, I feel it’s a silly question.
Also, may I ask for a good cloning software and how to do it? (A link will do)
Thank you
If the current drive has bad sectors, a clone operation probably won't work. It will get to that part of the drive and choke.
But, you can try it.
Specific steps for a successful clone operation:
Verify the actual used space on the current drive is significantly below the size of the new SSD
Download and install
Macrium Reflect (or Samsung Data Migration, if a Samsung SSD)
Power off
Disconnect ALL drives except the current C and the new SSD
Power up
Run the Macrium Reflect (or Samsung Data Migration)
Select ALL the partitions on the existing C drive
Click the 'Clone' button
Wait until it is done
When it finishes, power off
Disconnect ALL drives except for the new SSD
This is to allow the system to try to boot from ONLY the SSD
Swap the SATA cables around so that the new drive is connected to the same SATA port as the old drive
Power up, and verify the BIOS boot order
If good, continue the power up
It should boot from the new drive, just like the old drive.
Maybe reboot a time or two, just to make sure.
If it works, and it should, all is good.
Later, reconnect the old drive and wipe as necessary.
Delete the 450MB Recovery Partition, here:
https://social.technet.microsoft.com/Forums/windows/en-US/4f1b84ac-b193-40e3-943a-f45d52e23685/cant-delete-extra-healthy-recovery-partitions-and-healthy-efi-system-partition?forum=w8itproinstall
