Question Help about rams
Dec 10, 2019
I've got Asrock Fatal1ty Z270 Gaming K6.
I wanna add 32gb of rams on 3200mhz. any tip which rams should i buy?
PC Tailor
Herald
Welcome to the forums my friend!
On the Z270 chipset, you likely won't notice a difference between most RAM speeds. Intel's older chipsets don't quite scale the same way with RAM that Ryzen does. The later Z390 chipsets appear to show more of a difference however.
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3000 Memory ($99.99 @ Newegg)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-2666 Memory ($89.99 @ Newegg)
Memory: OLOy 32 GB (2 x 16 GB) DDR4-3200 Memory ($99.99 @ Newegg)
Total: $289.97
Generated by PCPartPicker 2019-12-10 17:42 EST-0500
