L Leyha Commendable Feb 21, 2017 174 0 1,680 May 7, 2017 #1 My house is often a power outage from the electricity center due to repair, 1bulan can be up to 3 blackouts, Of course like it will have a bad impact on my computer, then I have to install what tools to my computer?
Solution COLGeek May 7, 2017 You need an Uninterruptible Power Supply (UPS). Here is some info to help you find something in your area that you can afford: http://www.apc.com/shop/id/en/categories/power/uninterruptible-power-supply-ups-/computer-and-peripheral/back-ups/_/N-1nzwthz;jsessionid=iHIo57eI-1LtpJvrB3fyHt4e.prod_store01-2 http://www.schneider-electric.co.id/en/product-range/61883-back-ups/?parent-category-id=8000 https://www.google.com/search?q=uninterruptible+power+supply&ie=utf-8&oe=utf-8#q=uninterruptible+power+supply+indonesia
COLGeek Cybernaut Moderator Apr 6, 2009 59,562 5,307 184,340 May 7, 2017 #2 So, are you looking for just power protection for just your computer or your entire home? Where do you live and what is your budget? Upvote 0 Downvote
L Leyha Commendable Feb 21, 2017 174 0 1,680 May 7, 2017 #3 yes, around 20-30$, indonesia Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,562 5,307 184,340 May 7, 2017 Solution #4 You need an Uninterruptible Power Supply (UPS). Here is some info to help you find something in your area that you can afford: http://www.apc.com/shop/id/en/categories/power/uninterruptible-power-supply-ups-/computer-and-peripheral/back-ups/_/N-1nzwthz;jsessionid=iHIo57eI-1LtpJvrB3fyHt4e.prod_store01-2 http://www.schneider-electric.co.id/en/product-range/61883-back-ups/?parent-category-id=8000 https://www.google.com/search?q=uninterruptible+power+supply&ie=utf-8&oe=utf-8#q=uninterruptible+power+supply+indonesia Upvote 0 Downvote Solution
