HELP all games wont work!!
helpHelp23
hi guys i downloaded 2 games the one is kane and lynch deadmen,nfs most wanted 2012..so i use cccleaner to speed up my pc a bit i clean registry files and it was deleted and made a backup i don't know how to restore it because im not professional at pc's as other's do but when i launch kaneandlynch at startup it crash it say's..
Kane and lynch has stopped working it just that....
and in nfs most wanted when it is in loading screen after the main screen
it is infinite loading!! and the loading screen has no cars behind it.it should be there!!this is my rig
sapphire r7 250x 2gb
intel core i5 4460
x2 ssd 840 evo
G.SKILL Ripjaws Series 8GB (2 x 4GB)
viewsonic monitor(single)
would appreciate your help guy's thanks!
Just re-install the game it should work no need to format the thing entirely, if a restore point is available use it to restore your system to a previous state.
What windows you use? Search for 'restore point' and if you're lucky you can restore to before cleaner. I'm guessing both games were working before you ran it? Also I'd have a look at your cleaner log and see what was removed. I'm guessing something happened to your direct x files.
i am using windows 7 ultimate 32-bit....and i created a restore point after cleaner because i was thinking to format my storage and start again...
I think your right i have downloaded and install a new games it is resident evil orc
and it just work fine!!
If you saved the .reg file before deleting the keys you just click the file and it will restore all of the changes.
FYI you are not doing yourself any favors having 8gb of ram but a 32 bit OS that will only be able to use 4gb.
Never get the people who pirate software and dont even get the good one.
