HELP. All of my games freeze every few seconds.
MerseysideOtaku
A few days ago, I decided to replay Borderlands because I've got some extra time and I'm a bit bored. I launched the game, and every few seconds, the game would freeze. Only the visuals mind you, the audio for some reason still ran. The only way to fix the freezing would be to CTL-ALT-DEL and then press cancel, which took me back to the game, where I secured myself another 3-10 seconds of gameplay before I froze once again. I tried everything I knew to: turned the graphics settings down, reinstalled the game, updated my drivers, rebooted my machine, etc, all to no avail. So eventually, I gave up. Fast forward to an hour ago, and I decided I'm bored and needed something to do, so I pulled up Mass Effect. Three guesses what happened next, whoever said it did the same flipping freezing thing is 100% right. After that (and a lot of expletives), I decided to test out a few of my other games (Fallout 3, Skyrim, Dragon Age: Origins), and all of them did the same thing. Just as a bit of info, all of these games that don't work now DID work no more than 2 years ago on the same machine.
Also here are my computer specs if you need them (sorry if they're not the specific ones you need... never really had to copy/paste my specs anywhere):
System Information
Time of this report: 7/1/2015, 02:11:10
Machine name: USER-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150525-0603)
Language: English (Regional Setting: English)
System Manufacturer: FOXCONN
System Model: Inferno Katana
BIOS: BIOS Date: 05/11/10 15:56:55 Ver: 08.00.15
Processor: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 8184MB RAM
Page File: 4756MB used, 11608MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
Display Devices
Card name: NVIDIA GeForce GTX 460 v2 (X2)
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1205&SUBSYS_13613842&REV_A1
Display Memory: 4049 MB
Dedicated Memory: 978 MB
Shared Memory: 3071 MB
1. Temperatures measure around 60 degrees Celsius while a game is running. Not sure if that's good or bad, I've never really looked in to my PC temp before.
2. Just recently.
3. It's a desktop.
Temps seem alright.
When was the last time that you cleaned it?
That might actually be it. I haven't cleaned it in quite a while. I'm about to upgrade my GPU anyway so when I put it in I'll clean it out. Wish me luck!
Yeah cleaning it might do the trick! And what gpu may I ask?
