Hello,
I've come across a very annoying problem, and have exhausted all the usual methods of trying to troubleshoot it. Basically, my computer runs fine (using it to type this) but whenever I launch certain programs (not sure which programs triggers is) like Adobe Premiere Pro (but not After Effects) and CS:GO all my USB devices simultaneously disable and I have no option but to manually force shutdown my computer as I have no control of my keyboard ormouse. Interestingly the computer isn't "freezing" as I can still see the computer responding as normal providing updates like "USB device disconnected/not working" but I can't respond. In a number of situations the USB devices eventually reconnect after maybe 30 seconds or so, but then it occurs again not too long after.
I've currently reset my PC (windows 10 reset feature) twice now to no avail, have reinstalled about every driver (including graphics card) in Device Manager and updated everything. Have updated BIOS to latest version, have turned off my mild overclock, and have turned off power-saving features in Power Settings. I have also gone into Device manager and manually turned off the settings on USB root hubs and devices to do with the power-off feature to save power in low power states. I've checked for malware using malwarebytes and was fine. Everything points to a driver issue, but I don't know what else I can really do?
I've reinstalled Premiere Pro and CS:GO multiple times so it doesn't seem to be the issue; they're the only problems I've noticed with it so far (although I haven't opened many programs). My next thought was RAM, but I ran the Windows Memory Diagnostic tool and got nothing, and then another time I got a positive reading, so I'm not sure what's going on there. Same issue with Memtest. I've had the CPU replaced a while ago so I really don't think it's that (and the temps are fine; ~25C idle).
Any thoughts? Cheers.
Specs;
i7 6850k
Asus x99 Rog Strix MOBO
32gb DDR4 Corsair Vengeance RAM
H115i water cooler
GTX 1080 STRIX
850W Gold PSU
Samsung 960 Pro SSD
Samsung 850 EVO SSD
Specs;
i7 6850k
H115i water cooler
GTX 1080 STRIX
850W Gold PSU
Samsung 960 Pro SSD
Samsung 850 EVO SSD
