Help am panicking with graphics card!
Necromonger
44
I just found and bought an AMD R9 270x card. I installed it and connected the 2 power connectors to it. But then when I went to turn my PC on I have a black screen!
I connected it via HDMI to the motherboard then to the GPU HDMI. Nothing. My TV shows a signal from the mobo HDMI cable but non for the GPU HDMI. What did I do wrong?! Everything is spinning(CPU, GPU and case fans).
Please help me! Am first time builder.
I do hear a beep but it happens the second I power it on. This beep always happens whenever I turn it on. Didn't have problems with display or anything. Have had this PC for 2 days with no issues until now.
Okay so to fill in the gaps...
I built my PC without a GPU at first. Just this set up:
I5 4670k
MSI Z87-G43 mobo
Thermaltake 600W
8GB Corsair Vengeance
2 TB WD HDD
Disk/DVD Drive
I just got the card today(couldn't find it when I bought 90% of the components). So I installed it, from PSU I connected 2 6-pin power connectors. 1 was a 6+2 pin connector. I seated it properly too. Took my time and everything.
My expanded question is: Was I supposed to do any prep work before installing? Like install the GPU drivers first? Do I need to connect with VGA instead of HDMI???
Need help ASAP!
@lookerup
Thank you for the last info! I just switched the display settings in bios.. Now I see Windows 8...
Okay all fans are running including GPU fans... Downloading 270mb GPU drivers...
