Question help and dissapointement
Shadow_32
250
i bought a gaming laptop with gtx 3080 but i have awful results in far cry 5
i cant even get it to 60 fps on medium settings on 4k
these are my specs
Device name DESKTOP-G6EKN8H
Processor 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz 2.30 GHz
Installed RAM 16,0 GB (15,8 GB usable)
Device ID 7B9480AB-0C6C-48D7-83B7-A66FA041A9BD
Product ID 00326-10121-47741-AA413
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
it says i have like 15 emory of ram and the settings in the game does not even reach half of it but i still up getting only 40 fps and icant even get higher than that with lower settings either
Shadow_32
250
its not a special brand.. also this brand has done me solid twice but this tiem i am not sure... can you help me bench mark this soo i know i got what i payed for?
Shadow_32
250
the GPU is gtx 3080 super 16
windows 11 latest update
how much fps should i be able to pull with that n 4k ultra settings
Shadow_32
250
its odd it can run doom etenral on ultra 4k but on call of duty black ops cold war i have to take everything to the absolutly lowest and dlss does nothing just to get 58 fps makes no sense...
Makes all the sense in the world if you know how games work.
The CPU determines the maximum frames per second. The video card can only produce the frames the CPU calculates.
The CPU produces a wire frame for each frame seen on screen. The video card can do nothing without this.
The CPU sends the wire frame to the GPU. The GPU adds texture/skin/tessellation/lighting effects/water etc............. to the wire frame to make the frame you see on the screen .
It then sends it to your monitor.
So unless you turn up the video card settings higher than it can handle the CPU will always be the limiting factor.
take my system as an example.
R5 5600x
Asus prime X570
3060 TI Founders edition
16GB 3600 CAS16 ram 2x8GB sticks.
1 TB 970 evo+
Corsair RM850X
1080p monitor.
with a GTX960 installed on Warthunder I get 100-130 FPS low settings. High settings we drop to 60- 75FPS the video card becomes the limiting factor @100% usage.
With a RTX 3060 TI installed I get the same 100-130 FPS low settings. BUT I can turn all EYE CANDY or settings in the game to MAX and still get 100-130 FPS.
THE CPU is then the limiting factor. AND the video card is still only 80% usage.
If you run Unigine Heaven benchmark you can use the Camera View to toggle between Wire frame (CPU) and normal (GPU) added to wire frame from CPU.
