M milan Oppermann Reputable Oct 27, 2014 2 0 4,510 Oct 27, 2014 #1 Does my hp pavilion p6t desktop intel® coretm i3-2130 3.4ghz have an pci express cable or cable input in it as I would like to install a new graphics card?
ThatVietGuy Titan Nov 6, 2007 11,728 319 70,240 Oct 27, 2014 #2 It probably has a crappy, low-wattage PSU that will hinder what you can install. At most you'll probably be able to go as high as a GTX 750ti. Upvote 0 Downvote
M milan Oppermann Reputable Oct 27, 2014 2 0 4,510 Oct 27, 2014 #3 ThatVietGuy : It probably has a crappy, low-wattage PSU that will hinder what you can install. At most you'll probably be able to go as high as a GTX 750ti. yes but does it even have a pci e cable because I did not see one inside Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,728 319 70,240 Oct 27, 2014 #4 How am I supposed to know? If you've looked in there and didn't see a free 6-pin cable coming from the PSU floating around then, no, it's obviously not in there. Upvote 0 Downvote
