I've searched the forum for a while and found lots of conflicting information. The best advice (I believe) I found was an article to "how-to-clean-lcd-monitors" http://howtofixstuff.blogspot.ca/2012/03/how-to-clean-lcd-monitors.html
I have two Dell U3011's. I use the monitors for work and they would be fairly expensive to replace, so I'd really appreciate if someone can share a safe and effective method for cleaning them. Here are pics of the screen:
- Before cleaning remove the dust and any pet hair build up by using a soft dry lint free cloth or microfiber cleaning cloth and very gently remove from the screen.
- Do not press hard, push, prod or rub excessively against the screen surface.
Now dampen the cloth with some special LCD flat screen cleaner, distilled water or a 50/50 mixture of distilled water and isopropyl alcohol (do not use tap water as it leaves deposits and residue).
- Make sure to spray the cleaner onto your cloth first and not directly onto the monitor screen.
- Gently wipe the screen with the moistened cloth in a circular motion and do not leave any liquid on the screen surface.
