Help? Asrock 970 Extreme4 "Generate Serial ATA Driver Diskette"
Atlas17
4
Hey everyone,
I just finished my first build and everything's fine except I can't install any of my drivers due to a message I get after restarting reading "Generate Serial ATA Driver Diskette (Y/N)". Can anyone help me? I need to install my audio drivers and what not.
Thanks
Check your sata cables on your disc drive and hdd. Make sure they're plugged in.
edit: did you install windows or did you try and install the drivers first? If your trying to install drivers first it seems to bring up this floppy disk business.
I have already installed windows and all my other drivers worked fine except the asrock ones.
Also, I checked my SATA cables and they're all in fine.
I had the same problem and there were 2 things I needed to do. 1) Change the drive to IDE instead of AHCI and 2) Change the boot option to my windows hard drive (It was still trying to boot from my DVD drive with the ASRock drivers disc). Very dumb of me :)
