F freddieyjh Dec 5, 2018 2 0 10 Dec 5, 2018 #1 Hi, has anyone ran those two parts together? Looking at the mobo picture, i’m worried than the fan will be too big and hit the RAM slots. I have 2 hyperxfury 8GB ram cards currently. Also my case is Cooler Master Master Box 5.
Solution Dark Lord of Tech Dec 5, 2018 Hyper X Fury is not very tall for modules , should fit no problem. Your case easily supports the cooler.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Dec 5, 2018 Solution #2 Hyper X Fury is not very tall for modules , should fit no problem. Your case easily supports the cooler. Upvote 0 Downvote Solution
drivinfast247 Glorious May 29, 2018 7,845 1,646 47,940 Dec 5, 2018 #3 I had the same setup. Worked fine. Be sure to install RAM in A2 and B2 slots. Upvote 0 Downvote
F freddieyjh Dec 5, 2018 2 0 10 Dec 5, 2018 #4 Hi Drivin, great to hear that you have the same setup. So to confirm, all 4 of your ram slots are free and can be used? Upvote 0 Downvote
