I finished putting my rig together last night and fired it up. First power on and it didnt post.
I changed the port on the Video card to the second one and it posted. I went into the BIOS and monitored CPU and MOBO temps.
CPU temp was 35C
MOBO temp was 35C
I noticed the back fan on my shark case wasn’t spinning so I shut it down. Removed power cable and connected the 120MM case fan.
I powered it up, and every fan was spinning now. All good
The system wont post. I don’t even get any post error beeps.
I mess with a few cables and still nothing.
Im running a 660W PSU so power is not an issue. The 12V to the mobo along with the 24 pin connector is plugged in. I reseat everything and go again. It wont post and the monitor stays amber.
The PC seems to be locked by something because the power button wont shut the PC down unless I hold it down for 5 seconds.
I disconnect the DVD from the PRI IDE. I disconnect the SATA HDD. Still no post.
I reseat the VID card... no post.
I move the memory into different slots.. 1A 2A, 1A 1B, 1B 2B. Nothing, no error beeps and no post.
I remove the memory completely.. Beeeeeeep.. beep beep beep. ok memory error beeps on the MOBO.
I guess it’s the memory. I have TWINX2048 DDR 400 PC3200 3200PRO.
I look on Cosair site, they say the memory is compatible. In the ASUS book it doesn’t list the 3200PRO only the 3200C2 and others.
Is this a memory problem or is this a memory compatibility problem?
What’s really vexing me is that it posted up once!
Your help is greatly appreciated...
Check below for hardware...
CPU temp was 35C
MOBO temp was 35C
