Help asus formula vi sparked bottom right corner
dragon27
11
Ok so I was booting up it booted fine as I was logging in it turns off reboots and bam a spark arcs in what looked like the bottom right Hand corner of the motherboard any idea why and should I turn it on or should I wait need help
I would assume that something shorted on the motherboard. The motherboard is questionable. I would guess that if you power it up that the damage is already done. The other components are also questionable. If you can return the motherboard, I would do that now. If they will not accept the return, then you have nothing to lose by powering it up. I would do it with the other components removed.
my components are mb asus formula vi, cpu = i7 4770k oc @ 4.4ghz gpu = gtx 770 psu = ax860i, ram = corsair vengeance pro 16gb 2400mhz running @ 1866mhz all watercooled with acrylic tubing in a corsair 900d
should i just tell asus that the motherboard shorted on a standared boot up? or what
