(Help!)Asus H61M-Plus Mobo, LED lights green, But PC wont start
AGPC
258
I just bought a Asus H61M-Plus and an i5-LGA 1155 to replace my dieing AMD Phenom II BE. the problem is that when i press the power button nothing happens. i check and triple checked the switch connectors so i am 90% sure that is not the problem. also i checked ALL of the power cables and they too are in. Is the mobo dead or does anyone else have an idea?
UPDATE: The LED lights on the MOBO are green so i assume that the PSU is working.
Heres what i know works:
RAM: I used the same one in another PC
GPU: I used the same one in another PC
PSU: I used the same one in another PC
The Mobo and CPU are the new objects.
CPU: i5 LGA 1155
Mobo: H61M-plus
