[HELP] Asus z170-e VGA Red Light (photos inside)
MC48
Commendable
Jan 25, 2017
I recently bought and built a new computer. My computer starts up but I do not get a display on my monitor. My ASUS z170-e fails on the VGA test. The VGA Led light stays red. It's even red when my GPU is out of the system. I have done research on this and I've tried everything. I've tried switching ram slots, only 1 ram in each, both rams different slots, and pulling out my GPU. The light is stuck on VGA-LED.
Thanks for your help.
This is my build:
https://pcpartpicker.com/list/WNPcNN
asus z170-e
i5-7600k
Strix 1070 OC
Kingston Fury 2666-8gb
EVGA SuperNova 650w
PNY 480gb ssd
http://i.imgur.com/7WUuK2B.jpg
http://http://imgur.com/a/x7BIN
Edit: added photos
Edit #2: I'm reading that I may have to update bios before a z170 can work with a Kaby CPU. Will buying an updated BIOS chip work for this VGA-LED problem?
You can clear the bios by unplugging the PC and removing the cmos battery or using the jumper pins on the board (usually)
Thanks for the response! =]
I can't reach bios. The computer starts, fans are working, GPU is lighting up, but it won't get past the VGA test even without the GPU in the motherboard.
Thanks, I have read this too. I will give this a try later tonight when I get home from work. I wish it was a different LED light that was on... At this point I would think it would be easier to find a solution.
