I have the Corsair Cooling Air Series A70 HIGH-PERFORMANCE DUAL-FAN CPU Cooler.
I am replacing the dual fans. The fans attach to a plastic frame that then clips onto the side of the CPU cooler itself.
The fans are attached to the frame by 4 rubber “grommets” I want to say. The grommet extends from the frames and goes through both holes on the corners of the fan
While removing the old fans from the frames I tore off a couple of those rubber grommets.
Any ideas how to attach the dang fans now?
Thanks
View: https://imgur.com/a/dcWrseX
Thanks
