C CallumJToye Commendable Mar 10, 2016 8 0 1,510 Apr 22, 2016 #1 My AMD FX8350 is running at 1.4Ghz in stead of the default clock of 4 the Cmos has been cleared and this problem occurs ? can u help?
Solution Dark Lord of Tech Apr 22, 2016 TOTALLY normal , won't jump till you put some decent stress on it. It's a power saving feature. Also what specs?
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Apr 22, 2016 #2 It's probably not under load. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 22, 2016 Solution #3 TOTALLY normal , won't jump till you put some decent stress on it. It's a power saving feature. Also what specs? Upvote 0 Downvote Solution
