G
Guest
Guest
Archived from groups: alt.cellular.verizon (More info?)
I purchased an aftermarket battery from CellCountry.com It is a 1400
mAh Li-Ion for the LG VX3200. When I boot it says "use genuine
battery" power down in 10 seconds, then shuts down. Do I need a cable?
I e-mailed CellCountry.com three times and they didn't get back to me.
Any suggestions?he original battery and the new battery are both 3.7
volts. The only thing is the amount of amps, the original one is 1000
mah and the new
one is 1400.
Thanks,
Steve P.
mah and the new
one is 1400.
Thanks,
Steve P.
