Help between Gigabyte gaming 3 and MSI Z97 guard pro
ascheritt
11
Im torn between these two motherboards
Gigabyte GA-H97-Gaming 3
or
MSI z97 guard pro?
dont plan to OC since im planning to pair it with Intel i5 4590 and gtx 970.
Thanks!
asrock z97 extreme 4 is kinda out of the budget. :'v i can only shell out $120 for the motherboard. *ps i live in the philippines and the prices are 10-20% higher than newegg/pcpartpicker
wait. it says there that i5 4590 can be turbo boosted from 3.30ghz to 3.70ghz . so how do i activate the boost and which motherboard is applicable to apply that boost? thanks
