HELP ! blue screen after finish build
simjracer
32
Hi could any one please help me on understanding this
i've had the blue screen 3x today after finishing my build the lasted parts i fitted are
fx 4170 cpu with the cooler it came with
asus 7770 1GB gddr5 gpu
Kingston hyper ddr3 8gb 1600mhz
i've done no OC due to i dont no how to,
best thing about this is my computer aint doing any thing just on the net or just on desktop
this is what i get each of the time after i get the blue screen
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: d1
BCP1: 0000000000000000
BCP2: 0000000000000002
BCP3: 0000000000000008
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\052812-28376-01.dmp
C:\Users\Racer\AppData\Local\Temp\WER-49764-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
i couldn't get any info when the blue screen come up due to it only up for no longer then 5 second
i've checked all the drivers and all are up to date
the cpu temp is has now 12C in (core Temp 1.0) but in asrock oc tuner says 38C so which one do i go by??
thanks simon
[make sure you have the bios up to date. a lot of bios will be for cpu and ram codes. asrock bios is reading fine the other software is not. try hardware monitor or fanspeed to read your temps. with ram check that your ram is on the mb guild. if you think it a ram issue put in one dimm in a0 or a1 and see if it blue screens. also run cpu-z look at the memory and spd info tabs.
then go into the bios ans check that the mb read the spd right and set the ram speed..voltage and timing (ie (9-9-9-24t).
simjracer
32
hi thanks for your help i check the gpu drivers off asus website and i got the up to date driver and my bios is up to date and the ram is for my motherboard and i also reset bios, i also got windows to do a test on the ram and that came out fine
i like to know if it my hhd coz i use piriform defraggler and it saying disk health has WARNING so could that be it???? due to all my rig is new out of the box apart form my hhd
this is my rig
MOBO: asrock 960GM-GS3 FX
CPU : FX 4170
RAM : kingston hyper ddr3 1600 8GB
PSU : powercool 750watts
GPU : Asus hd7770 1GB GDDR5
HHD :SEAAGTE 300GB SATA II 7200RPM
if any one got any ideas to improve my rig i would like to hear and how do you OC the ram and cpu and would that help
plus do any know what BCCODE 124 is??? has that was the last one to pop up before i staring testing and resetting bios
thanks simon
simjracer
32
hi i got this from the last blue screen
The computer has rebooted from a bugcheck. The bugcheck was: 0x000000d1 (0x0000000000000000, 0x0000000000000002, 0x0000000000000008, 0x0000000000000000
all my driver are up to date and also windows update too still getting the blue screen
i've done memory test done ckhdsk /r, virus check , disk cleaner,
i've got this from C:\Windows\Minidump\052812-28376-01.dmp
n t o s k r n l . e x e
h a l . d l l
k d c o m . d l l
m c u p d a t e . d l l
P S H E D . d l l
C L F S . S Y S
C I . d l l
W d f 0 1 0 0 0 . s y s
W D F L D R . S Y S
A C P I . s y s
W M I L I B . S Y S
m s i s a d r v . s y s
p c i . s y s
v d r v r o o t . s y s
p a r t m g r . s y s
v o l m g r . s y s
v o l m g r x . s y s
p c i i d e . s y s
P C I I D E X . S Y S
m o u n t m g r . s y s
a t a p i . s y s
a t a p o r t . S Y S
A s r R a m D i s k . s y s
s t o r p o r t . s y s
a m d x a t a . s y s
f l t m g r . s y s
f i l e i n f o . s y s
N t f s . s y s
m s r p c . s y s
k s e c d d . s y s
c n g . s y s
p c w . s y s
F s _ R e c . s y s
n d i s . s y s
N E T I O . S Y S
k s e c p k g . s y s
t c p i p . s y s
f w p k c l n t . s y s
v o l s n a p . s y s
s p l d r . s y s
r d y b o o s t . s y s
m u p . s y s
h w p o l i c y . s y s
f v e v o l . s y s
d i s k . s y s
C L A S S P N P . S Y S
a v g r k x 6 4 . s y s
A V G I D S E H . S y s
A t i P c i e . s y s
c r a s h d m p . s y s
d u m p _ a t a p o r t . s y s
d u m p _ a t a p i . s y s
d u m p _ d u m p f v e . s y s
can any one help me try to find what this means please thanks simon
