Hello, I wanted to know if a GTX 560 non-ti (gigabyte) will be bottlenecked by a Q9300 oc @ 3.2 ghz. If so, should I go with a GTX550 ti or a GTX 460 ti and will they be bottlenecked as well. Thanks !
720p is such a low resolution [ screen size is NOT important ] that a 560 ti is actually over kill
Make sure Vsync is enabled in the driver or you may damage the tv
You can damage a TV/Monitor by not having Vsync? Please explain :O
Also yes i'm pretty sure you could plug HDMI and use your TV's speakers, thats what my TV seems to do when i turn off my sound card and i'm plugged via HDMI.
