[HELP] BSOD Code:24
Ismaeel96
65
hi, sometimes when i start up CA or other games and play for a while or sometimes instanly i get a BSOD and i get the error code 24. my friend has pretty much same specs but a fx 6300 instead of a fx 4100 and the game works fine for him.
(just reinstalled win7 for this reason BTW it didnt used to happen until recently)
My specs:
Fx 4100 CPU OC@4.5 /w cooler master evo cooler
Radeon HD 7850 normal clocks
seagate barricuda HDD 250GB @7200RPM
4 gb ram (patriot brand) 1333 mhz
500 watt psu (inland)
BSODs:
Code:
this bluescreen is reaccuring
Problem signature:
  Problem Event Name:	BlueScreen
  OS Version:	6.1.7601.2.1.0.768.3
  Locale ID:	1033
Additional information about the problem:
  BCCode:	124
  BCP1:	0000000000000000
  BCP2:	FFFFFA8004D4D378
  BCP3:	0000000000000000
  BCP4:	0000000000000000
  OS Version:	6_1_7601
  Service Pack:	1_0
  Product:	768_1
and if u know how to fix this, that would be great :D  VVVV
Problem signature:
  Locale ID:	1033
  BCCode:	1000009f
  BCP1:	0000000000000004
  BCP2:	0000000000000258
  BCP3:	FFFFFA8003A01B50
  BCP4:	FFFFF80000B9C3D0
  Service Pack:	1_0
  Product:	768_1
if u need any more info plzz ask
Error code 24, NTFS_FILE_SYSTEM. Usual causes: Disk corruption, insufficient physical memory, Device driver, Indexing, Resident antivirus, backup, defrag programs, Disk/Drive failing/failure'
Open a console session as administrator, on the command line type "chkdsk c: /f /v /r" (without the quotes), then press <return>. Answer the resulting prompt with Y<return>, then reboot. The check will take a long time.
