HELP - BSOD ntoskrnl.exe
tdoe21
19
hey guys, ive been getting BSOD with the same error for over a year now. Happens out of the blue and kinda just leave it just cause im pretty crappy with computers. But now im determined to locate a solution.
Here is the WhoCrashed from today
On Tue 5/1/2018 3:17:44 PM your computer crashed
crash dump file: C:\WINDOWS\Minidump\050118-7437-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1640E0)
Bugcheck code: 0x50 (0xFFFFE100006F56D8, 0x0, 0xFFFFF80274F74E7A, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
and
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: bcmwl63a.sys (bcmwl63a+0xE1D1F)
file path: C:\WINDOWS\system32\drivers\bcmwl63a.sys
product: Broadcom WiFi Driver wireless driver
company: Broadcom Corp
description: Broadcom WiFi Driver wireless driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bcmwl63a.sys (Broadcom WiFi Driver wireless driver, Broadcom Corp).
Google query: Broadcom Corp PAGE_FAULT_IN_NONPAGED_AREA
I was just playing wow and it happened. It usually happens when downloading stuff with the Epic Games launcher or using the xbox live app party chat feature.
any help would be amazing!
Both are caused by the same wireless network driver. Get a update from the vendor. Ie if it came with your machine go to the machines vendor website and look for a broadcom WiFi driver update. If it is add-on WiFi usb device you have to get the driver update from the device vendor. In Some cases you might need to update your bios and usb port drivers from your motherboard vendors website.
