Hi, so i need a new computer i've had this one for about 6 years and it's terrible and i can't stand using it anymore
The things i want to use it for are playing minecraft on max settings and maybe some other games in the future.
Approximate Purchase Date: Tonight or tomorrow
Budget Range: Approx. 570$, Can't go any higher then it is right now unless it absolutely has to.
System Usage from Most to Least Important: Gaming,Internet,Videos
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Websites for Parts: Tigerdirect.com, newegg.com, Amazon.com,Ncix.com
Parts Preferences: Whatever works
Overclocking: maybe(Not very likely though)
SLI or Crossfire: maybe(not very likely though)
Will this work or is there parts that should be changed?
CPU
Intel BX80637I33220 Core i3-3220 Processor - Dual Core, 3MB L3 Cache, 3.30GHz, Socket H2 (LGA1155), 55W, 650-1050 MHz, Fan
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3734679&sku=I69-3220
Motherboard
ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
Storage
Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM Desktop Hard Drive - WD5000AAKX
Video Card
ASUS HD7770-2GD5 Radeon HD 7770 GHz Edition 2GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121642
Case
Cooler Master HAF 922M RC-922M-KKN3-GP Black ATX Mid-Tower Computer Case with USB 3.0 and Black Interior - 5 External 5.25" Drive Bays, 5 Internal 3.5" Drive Bays, 2 200mm Fans, 1 120mm Fan
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4631382&sku=C283-1223
Power Supply
CORSAIR Builder Series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Memory
Kingston HyperX KHX1600C9D3K2/8GX 8GB Desktop Memory Kit - DDR3, (2 x 4GB), PC3-12800, 1600MHz, CL9, Intel XMP Ready
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7104116&sku=K24-9917
here it is on http://pcpartpicker.com/p/rj2C
CPU
Motherboard
Storage
Video Card
Case
Power Supply
Memory
