[SOLVED] help build a Budget Gaming PC 400$ - 450$
adam19255
Upstanding
Dec 13, 2018
119
56
I will assume you have a PSU and case because you haven't listed them here so, this is what I recommend:
AMD Ryzen 3 2200G - https://www.amazon.com/AMD-Ryzen-Processor-Radeon-Graphics/dp/B079D3DBNM/ref=as_li_ss_tl?ie=UTF8&qid=1546001647&sr=8-1&keywords=2200g&linkCode=ll1&tag=xm3a06-20&linkId=38b1a417d2212833f45d9742a921eb7d
ASRock B450M - https://www.newegg.com/Product/Product.aspx?Item=N82E16813157842&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
G.SKILL Aegis 8GB 2666MHz - https://www.newegg.com/Product/Product.aspx?Item=N82E16820232722&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Crucial MX500 500GB - https://www.amazon.com/Crucial-MX500-NAND-SATA-Internal/dp/B0784SLQM6/ref=as_li_ss_tl?ie=UTF8&qid=1546001686&sr=8-1&keywords=mx500&th=1&linkCode=ll1&tag=xm3a06-20&linkId=56d784b32415ddd48177596b862dd5fc
PowerColor RED DRAGON Radeon RX 570 - https://www.newegg.com/Product/Product.aspx?Item=N82E16814131717&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
So... the same CPU, better motherboard, better SSD, better RAM, better GPU, and no HDD, I decided to remove the HDD because I peaked you a 500GB SSD for a good price if you want to buy the HDD then you can of course but it will be above the budget you have.
Total costs: 427$
Total costs with HDD: 472$
adam19255
Upstanding
Dec 13, 2018
119
56
Total costs: 427$
I'm assuming you already have a case and PSU. Please list the PSU you have to make sure it can handle a decent GPU.
I'd get a larger size SSD now. You can get a large HDD later. As it is an easy upgrade. Plus after loading games off an SSD. You'll never want to use a HDD for games again.
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor ($129.99 @ Newegg Business)
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard ($72.85 @ OutletPC)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory ($61.98 @ Newegg)
Storage: Team - L5 LITE 3D 480 GB 2.5" Solid State Drive ($49.99 @ Newegg)
Video Card: Sapphire - Radeon RX 570 4 GB NITRO+ Video Card ($139.99 @ Newegg)
Total: $454.80
Generated by PCPartPicker 2018-12-28 09:28 EST-0500
