[SOLVED] Help build a solid streaming Pc?
HerEyeSin
Proper
Feb 19, 2019
207
Ok so I’m going to be buying a Pc Of around 4000$ but I won’t have it for a while. I also will want to stream and thought while I have 1500$ on me right now I can buy a streaming PC to play on until I get my $4000 PC. Could someone help me build a PC that is 1500$ runs games like rainbow 6, insurgency, well. Also can I buy a 240hz monitor right now so when I buy my other PC I won’t have too? As in if my PC is o my running at 120 FPS will it run ok on a 240hz monitor?
My 4000$ build will have intel CPU. Idk if that matters for connecting both PC for streaming
WildCard999
Herald
$4K for a gaming build is a bit overkill (can be done with top of the line parts for under $3K) but streaming @1080P/240 (either lower settings or FPS) is pretty doable.
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor ($249.89 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 Black Edition 42 CFM CPU Cooler ($40.98 @ Walmart)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard ($129.00 @ B&H)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($104.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive ($67.99 @ Adorama)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: Zotac - GeForce GTX 1070 8 GB Mini Video Card ($299.99 @ B&H)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($55.48 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 650 W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($98.89 @ OutletPC)
Monitor: LG - 27GK750F-B 27.0" 1920x1080 240 Hz Monitor ($309.89 @ OutletPC)
Total: $1471.88
Generated by PCPartPicker 2019-02-28 16:26 EST-0500
Added in the OS as people who are watching your stream probably don't want to see the Windows 10 watermark.
As for your $4K build it depends on when your ready to build, Ryzen 9 3rd gen will probably give the 9900K a run for the money.
Reactions: HerEyeSin
WildCard999
Herald
Total: $1471.88
