HELP - build PC - Thank you!
Computech
14
I want your help to build pc with Case Midi Xman Gamer Black-Silver please if you can say me what motherboard, psu, gpu, cpu to get inside
thank you!
Here is the base build I would recommend, and we can do some tweaking since the price is so low (thanks to you already having some components).
PCPartPicker part list: http://uk.pcpartpicker.com/p/q2bPgs
Price breakdown by merchant: http://uk.pcpartpicker.com/p/q2bPgs/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£169.98 @ Ebuyer)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.25 @ Scan.co.uk)
Motherboard: Gigabyte GA-H81M-HD3 Micro ATX LGA1150 Motherboard (£41.99 @ CCL Computers)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory (£52.98 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£35.94 @ Aria PC)
Video Card: EVGA GeForce GTX 780 3GB...
Please help us help you better. If someone answers your question without asking for more information to actually help you get what you really want...then you already know that they are just throwing out cookie cutter and quick answers. I want to actually help you as much as possible which is why I ask these questions.
If you have already provided some of this information, and see the question below, that is merely to clarify what your posting already stated.
1. Do you need a keyboard? Any preferences? Wired/wireless/mechanical?
2. Do you need a mouse? Any preferences? Wired/wireless/DPI?
3. Do you need a monitor? If you already have a monitor/tv, what type is it and how many hz is it? Do you plan on using multiple monitors? Or do you have any monitor/tv preferences? Screen size, built in speakers, resolution, refresh, hz?
4. Do you want a blu-ray drive, dvd/cd drive, or no drive? If you already have one, what is it?
5. Do you prefer Intel or AMD processors? If you already have a processor, what is it?
6. Do you want to be able to overclock the processor?
7. Do you prefer NVidia or AMD graphics cards? Do you plan on using multiple GPUs at a later date?
8. Do you plan on overclocking the graphics card?
9. Do you want to have more options for upgrading later on, such as adding extra RAM or running multiple graphics cards together?
10. What operating system do you prefer, Windows 7 or 8.1, or Ubuntu/Linux? If you already have an operating system, then what is it specifically? For example: Windows 7 Home Premium 64 bit. (list the entire specifications for your operating system. Check this link if deciding what Windows OS you want http://msdn.microsoft.com/en-us/library/windows/desktop/aa366778(v=vs.85).aspx )
11. Does your budget include the operating system?
12. Do you prefer air cooling or liquid cooling?
13. Is there a particular case size you would like to go for, mid tower, full tower, etc?
14. Is there a particular theme or color scheme that you prefer, or a particular style case? (Please give a few examples)
15. What is your budget, minimum and maximum costs?
16. What sort of games or programs do you want to use? (Please give plenty of examples)
17. What settings, fps, resolution do you want to play those games at?
18. What country do you live in, so we can know what currency and/or sites to link for you?
19. Do you have a hard drive type preference, such as normal hard drive, hybrid, or SSD? Or do you want a smaller SSD for the operating system and a normal hard drive for saving files to?
20. Is there any other component that you already have that was not asked about specifically already? If so, what is it?
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($112.98 @ OutletPC)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($77.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card ($129.99 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($25.99 @ Newegg)
Total: $415.93
thank you very much for your answer!!!
1) I have wired keyboard
2) I have wired mouse
3) I have screen 19 'samsung
4) I have a dvd-rw
5) I prefer intel cpu
6)I am not able to do overclocking the processor
7) I prefer nvidia gpu
8) I am not able to do overclocking the gpu
9) Νo I will not
10) I have windows 7 ultimate 64bit
11)No
12)Air cooling
13)Case Midi Xman Gamer Black-Silver
14)No
15) 1000Euro maximum
16)I want to filter sounds
17)-
18)Cyprus
19) Normal hard drive
20)sound card
Thank you again for your reply!
Can you link to your particular case? And does it already have a power supply, and do you already have it? I am asking for that information because PCPartpicker uk site does not offer it in their parts list.
Yes my budget is 1000 Euro and I want to filter sounds and you can play and a game (eg call of dutty)
http:// i don't have power supply
Video Card: EVGA GeForce GTX 780 3GB Superclocked ACX Video Card (£378.60 @ Aria PC)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply (£65.99 @ Aria PC)
Total: £769.73
I left out the case because I guess you already have it. You already have an optical drive and operating system too. I left out a sound card since this motherboard has built in 7.1 sound. If you would like a more powerful sound card that is different, we could probably add it, but there is not much point since the motherboard already has it.
I went with your requests of Intel and NVidia. Although you don't plan on overclocking, I picked out an overclockable k version of the Intel CPU because the clock is higher than the non k version. And went for a bit more powerful of a PSU since the cost was just a bit more for a lot better one. I always like going with 16 GB of RAM, but you don't really need it, so I left it out.
We could technically probably swing for an i7 quad core if you wanted, but they are not really needed for gaming applications right now, and doubtful it will be a huge boost for what you are doing. If you want to adjust anything, then let me know and we can see what to change.
I have a problem, I purchased from this site http:// can you please view and tell me what would be the best choice?
No I have not bought, simply because it is store in my country and I'll get it immediately if you can look and tell me what you can buy from there
thank you for your reply!
I will get at wholesale price for this consult my friend!
I know there is no option like than the one you suggested to me just if you will please help me to find the best possible solution
Unless you are getting the computer at "wholesale" of less than 1/2 the cost...or actually closer to 1/3 the cost that they want, then it is not worth it at all. And then using that logic, if you can get the computer for 1/3 the cost, then get the most expensive one for your budget, if that is the company you are going with. Otherwise go with a different company that actually gives a decent deal. good luck
Okay, my friend probably will prefer your own offer and let a little lapse!
Thanks again to all for your time and for your interest!
